Archived from groups: rec.games.pinball (
More info?)
Yes, you are correct about that.
"frog" <van.nevel@verizon.net> wrote in message
news:zm4Se.101$9q4.78@trnddc08...
> as I understand it, the X4 would emulate the early boards, but the later
> sound boards had more complex sounds that it does not do.
> "Steve B." <flippers*no*spam*@sashimi.org> wrote in message
> news:RrqdnZ2dnZ3r1lrbnZ2dnZ7Qhd6dnZ2dRVn-yZ2dnZ0@comcast.com...
>> why not use the board's built in sound for the tones?
>> news:7wSRe.20342$k32.13702@trnddc08...
>> > yeah, after I posted I thought, duh, bad connection is the first
>> > choice.
>> > After all, it is a system 1. The board is a new PiX4 board, so it
> better
>> > not be a failed driver
. Also, RTFM applies, there is a diagnostic
>> > button
>> > on the sound card. Too late in my house to be checking sounds, will
>> > try
>> > again tomorrow.
>> > "John Robertson" <spam@flippers.com> wrote in message
>> > news:2005090123171016807%spam@flipperscom...
>> >> On 2005-09-01 22:39:10 -0700, "frog" <van.nevel@verizon.net> said:
>> >> > Googled for this but the results are dominated by system 80
>> >> > problems....
>> >> > I have finally gotten my Hulk machine up and running, except that I
>> >> > only
>> > get
>> >> > tones for 1000 points and 10 points, but no 100 point tones. I
> swapped
>> > out
>> >> > the sound board and I got the same result.
>> >> > Any and all suggestions welcome.
>> >> > frog
>> >> Either a bad connection or a failed driver transistor on the
>> >> lamp/solenoid board. Assuming two different sound boards had the same
>> >> problem in the same game.
>> >> John :-#)#
>> >> (Please post followups or tech enquires to the newsgroup) John's
>> >> Jukes Ltd. 2343 Main St., Vancouver, BC, Canada V5T 3C9 Call
>> >> (604)872-5757 or Fax 872-2010 (Pinballs, Jukes, Video Games)
>> >> www.flippers.com "Old pinballers never die, they
>> >> just flip out."
