Ati radeon hd 4350 drvers giving problems
Hello, I would like to uninstall all ati/amd drivers. I have tried many thins but it is not happening. So I have Decided to reinstall windows 7. I was having code 37 error in the device manager. I want to format only the system drive "c" only. Please help
6 answers Last reply
More about radeon 4350 drvers giving problems
  1. boot from windows disk, go to advanced and format the hard drive, select the empty hard drive to install windows onto and you're done
    will it affect other partitions
  3. when you format it deletes partitions yes
  4. You DO NOT have to format the other partitions. You can just delete C: then reinstall on it. You will have to reinstall programs that are on the other partitions though
    and how will i boot the cd/dvd the code 37 error has even effected my cd/dvd drive. its not working.
  6. Try detatching all other hard drives. Just have your CD and primary hard drive attached. See if that helps.
Drivers ATI Radeon Windows 7
