R raju_70 Distinguished Sep 27, 2011 1 0 18,510 Sep 27, 2011 #1 monitar name is zabronik use in video card 3 ic 2489NA , STV9556 & 1 more i dont no number......
CompTIA_Rep Splendid Jul 13, 2006 4,868 2 22,865 Sep 27, 2011 #2 A VGA (dsub) cable transmits red/blue/green. If one or two streams are bad, you get whats left. in this case, the red and blue are not getting to the monitor. Check your cable, replace it if you can. Check the pins on the cable. Upvote 0 Downvote
