Solved
Hdmi audio problem
  • High-End Audio
  • Audio
  • Video
  • HDMI
Last response: in Home Audio
February 15, 2013 9:03:06 PM
I bought a dvi to hdmi converter and plugged my hdmi cable into my tv i get video but no sound.It says in my device manager that i have the souftware. when i try to set amd high definition audio device to my default playback it says its unplugged while im getting video. i have a hd 7850 graphics card with updated drivers what should i try?
More about : hdmi audio problem
Best solution
February 16, 2013 10:10:00 PM
Your DVI port does not send audio, if you got a converter with an audio jack, you need to use that to get sound.
February 24, 2013 3:54:24 PM
Best answer selected by rusdog10.
m
l
