S sweetkeys Honorable Feb 19, 2013 3 0 10,510 Feb 20, 2013 #1 Try switching to the Edit Program mode,then you can change the sounds manually by the up and down keys..
soundguruman Splendid Mar 3, 2010 4,816 0 23,460 Feb 20, 2013 #2 http://www.korg.com/contactus.aspx contact Korg support. Upvote 0 Downvote
S sweetkeys Honorable Feb 19, 2013 3 0 10,510 Mar 3, 2013 #3 sweetkeys : Try switching to the Edit Program mode,then you can change the sounds manually by the up and down keys.. I had the same problem but reloaded the sounds and I am now up and running! Upvote 0 Downvote
S sweetkeys Honorable Feb 19, 2013 3 0 10,510 Mar 3, 2013 #4 I had the same problem but reloaded the sounds to the factory settings ,now I am up and running! Upvote 0 Downvote
