Tom's Hardware > Forum > Smartphones & PDAs > Palmpilot > Connection problems:T3, Palmone Wi-Fi card & SBC-2Wire Hom..
Forum Smartphones & PDAs : Palmpilot - Connection problems:T3, Palmone Wi-Fi card & SBC-2Wire Hom..
Archived from groups: comp.sys.palmtops.pilot (More info?)
Can anyone offer set-up help? I've installed the card software onto the T3,
entered the SSID and the WEP key, and the device shows that it connects with
a strong signal, but when I try to use WebPro (3.0) I get error messages
saying that it can't find a host or the proxy server... Thanks!
Sponsored Links
> T3,
> with
I'm using version 3.5 (Zire72) hope this helps. From WebPro, go to
Options/Preferences/Advanced and check the proxy settings. If you want to
use the Palm Proxy, mine is set to: webpro.palm.com:8827
Try unchecking this option also to not use the proxy.
WyreNut
If you had to ~run~ for your life, how long would you live?
Reply to Anonymous
Thanks for the response!
Unfortunately I'm still having problems. I've made sure I've got the right
proxy server entered, and I've tried browsing without the proxy server as
well. Still no luck. I'm not able to connect using Versamail either. It's
strange. The T3 shows that it's connected with a strong signal, but it
doesn't appear to be able to access the internet. My network at home is
through a SBC/2Wire HomePortal 1000SW. Everything appears to be set up
right, I'm wondering if maybe it's an issue with my router or my DSL
provider. I saw a post on a different thread where there was another SBC
subscriber having problems connecting with the Wi-Fi card too. I'm going to
try taking it to a public hotspot and see if I can connect there...
"WyreNut" <me@home.org> wrote in message
news:0jHzd.289348$HA.212362@attbi_s01...
> > T3,
> > with
> WyreNut
Reply to Anonymous
right
server as
It's
it
is
up
SBC
going to
onto the
> > > T3,
connects
> > > with
messages
want to
> > WyreNut
I have my PalmOne Wi-Fi card installed in my Zire72s and have the same
problem with my router... and my router is a 2Wire, too, but with a
different provider. It looks like the Proxy Address "webpro.palm.com"
does not exists!! Palm was to be the top of the line but I am very
dissapointed on this Wi-Fi card. Do anyone have any idea???? :-(
Reply to Anonymous
"SkullTracer" <skulltracer@hotmail.com> wrote in message
news:1104977815.374230.310220@z14g2000cwz.googlegroups.com...
I have the card in a T3 and it works fine at work. I don't have a
wireless router at home so cannot test it. But it does work as
advertised in my normal WiFi work environment.
gcisko@hotmail.com
Reply to Anonymous
I have had similar problems with a Zire72s connecting to my Netgear
wireless gateway. I solved the problem by allocating a fixed IP address
to the Wi-Fi card's MAC address within the router and it has worked
perfectly since. I was hoping the problem was with the gateway (despite
three PCs working fine) as I would like to use the Zire/Wi-Fi card combo
at hotspots where I will not be able to allocate a fixed IP address.
Reply to Anonymous
There are 1343 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
