How to add surround sound setup to your PC?
  • High-End Audio
  • Genius
  • Speakers
  • Audio
Last response: in Home Audio
March 10, 2013 6:22:30 AM
Hello hello, not sure if my categories are correct but hay, close enough.
Im currently using an Aiwa digital audio system and want to know if i can add my Genius 2.1 speakers too for a more surround sound experience???
Current Aiwa System link - http://www.google.co.za/imgres?imgurl=http://safe-img02...
Genius 2.1 speakers link - http://www.google.co.za/imgres?imgurl=http://www.compuw...
If the sounds from the different speakers will clash then i wont do it but i need some help from you guys..
Thanks
P.S dont know where to plug in the 2.1's because the green audio jack is already being used by the aiwa.
More about : add surround sound setup
March 10, 2013 9:43:52 PM
you might be able to plug it into the LR/RR port and get something out of it but i'm not sure as i havent tried it myself. generally speaking its not usually worthwhile to do what you suggest.
for less than $100 you can buy a brand new logitech speaker set in 5.1 surround. used you can buy them for half or less.
another option would be to go out and aquire a used home theater system and hook it up.
just some thoughts.
m
l
