Monitor connection is bad
Last response: in Computer Peripherals
October 15, 2011 12:58:55 AM
Monotior connection is very loose on desktop tower. Monitior power light comes on the in about 30 sec then goes off. Any one have any instruction on how to repair it or replase it. Thanks
More about : monitor connection bad
October 15, 2011 2:42:50 AM
Are you sure the monitor cables (BOTH the signal and the power one) are well plugged at both ends?
Also check out your power saving configurations.
a c 99 C Monitor
October 18, 2011 2:30:44 PM
This is not usually a connector issue, rather a power supply issue, or system board issue. Does it actually feel loose?
