Hi there,
We have installed the windows 7 hot fix 'KB2739286' i.e. about An update that adds support for the new currency symbol of the Turkish Lira.
After installing we are able to see the new currency symbol in ms word,excel and regional setting.
But one of our application use the regional setting to display the currency symbol/format. Instead of the new symbol our application is showing the '?' symbol.
Before this fix, our application works fine with the old currency symbol.
Any idea about this?
Our application uses the MultiByte Character Set(MBCS) to display the symbols. I have doubt that this fix is updated the unicode forgot to update the respective code page which is used in MBCS.
Thanks in advance for your support and views
Best regards
Danbo
Best regards
Danbo
