Tom's Hardware > Forum > CPU & Components > CPUs > can i still use this cooler? please help!
Forum CPU & Components : CPUs - can i still use this cooler? please help!
greetings!
please take a look at this picture:
<A HREF="http://666kb.com/i/zzdxcnvogdfk.jpg" target="_new">http://666kb.com/i/zzdxcnvogdfk.jpg</A>
i accidently removed a part of this "heat pad" on the bottom of my boxed athlon 64 cpu cooler (see left lower corner). my question is now:
can i still use it? or do i have to remove the whole pad
and apply artic cooling (or similar). i do not overclock, it is an athlon 64 3500+
thanks for your help!
greetings, sph
Sponsored Links
even if it was the whole pad I would still suggest taking it off and replacing it with Arctic Silver 5. Even if you don't do overclocking the as5 will help keep your CPU cooler and extend the life of the CPU. Cooler is always better.
Xaser 3 case with 420W TT PSU
AXP2500 (11*200 at 1.85v)
9800 Pro 128MB (stock speeds)
NF7-S v2.0
PDP DDR400 1GB(2-3-2-5)2.6v
Lite-On SOHW-832S
WD 80GB 8mb buffer caviar edition.
Reply to Robc1880
Is it one of the new winchesters? If it is, you better return it, so it can go to an ocer, no point in having one of those if you aint ocing. OK so I'm kidding. Dont sweat that little scratch. If it is a 90 nano part, you could probably take off half of the TIM, without worry. If it's a 130 nano part, still no problem.
Reply to endyen
STOP! Send this to me immediately for testing along with the CPU. I will give you an opinion in a couple of months. Better safe than sorry!
Abit IS7 - 3.0C @ 3.6ghz - Mushkin PC4000 (2 X 512) - Sapphire 9800Pro - TT 420 watt Pure Power
Samsung 120gb ATA-100 - Maxtor 40gb ATA - 100
Sony DRU-510A - Yellowtail Merlot
Reply to Cybercraig
You can still use it
Reply to Nights_L
good idea, but instead send it to me
______________________
<A HREF="http://www.moviewavs.com/MP3S/TV_Shows/Simpsons/flanderssong.mp3" target="_new">Audio Sig</A>|<A HREF="http://img113.exs.cx/img113/3772/c3othgrichpls.jpg" target="_new">Bored...me?</A>
Reply to Ned_Flanders
If he sends it to you, you'll probably use the "penis cooling method" and get it all sticky.
Reply to endyen
There are 1114 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
