L lojo55 Distinguished Aug 10, 2010 7 0 18,510 Aug 10, 2010 #1 When I plug my Acer into AC, the light blinks red. Does it turn to green when it's fully charged?
buwish Splendid Dec 16, 2008 9,854 1 31,460 Aug 10, 2010 #2 It should hold a solid color when it is fully charged (not blink). Does it end up doing that or does it continue to blink even when fully charged? Upvote 0 Downvote
L lojo55 Distinguished Aug 10, 2010 7 0 18,510 Aug 10, 2010 #3 That's what I need to know. How do I tell when the battery is fully charged? When the light stops blinking? Is there another way to tell? I have no way of telling that I KNOW of. Thanks Upvote 0 Downvote
L lojo55 Distinguished Aug 10, 2010 7 0 18,510 Aug 10, 2010 #4 The light stays red now, but when I unplug it, the screen goes blank, so apparently I need a new battery? Upvote 0 Downvote
hang-the-9 Titan Mar 25, 2010 60,387 1,081 152,940 Aug 10, 2010 #5 Try reseating the battery, sometimes that helps. If that does not work, either the battery or the connectors on the laptop are bad. Upvote 0 Downvote
L lojo55 Distinguished Aug 10, 2010 7 0 18,510 Aug 10, 2010 #6 Thank you, I took the battery off and put it back on and now it's charging. Up to 96% now. Thanks Upvote 0 Downvote
