Well, I'm trying to play Blood1, and in XP it only works in 320x240 (the other options gives me a garbled screen). I've booted into CMD and I can get a resolution of 800x600, but the sound doesn't work. I pretty much know nothing about CMD, but when I try to enable the sound it says device cannot be found at selected IRQ (it's the right one I'm almost sure, it's the one that works in XP). Is there a DOS drivers I need to get or something? I have a Turtle Beach Santa Cruz if that helps or makes a difference.
