I am a TA for a first year biology course (as many of you know), anyway today one of my students tried to convince me that the heat problem with the Intel Prescott 3.0 Ghz CPU is no longer an issue, and that these CPU's run at the same temps as an AMD A64 3200+. I disagreed, and proceded to ignore all of the other students in the class (whom probably had real problems) just so that I could argue the point with him. It's not that I am trying to prove him wrong or anything, but I would be interested in hearing some of your input on the issue.
I believe they put out around 10% less heat. That's still over 30% more than the A64.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
I just posted this in another thread, but I'll post it here too:
Here's my Celeron 2.66 (133FSB) 330J on a P5GDC running at 4ghz (200FSB). This is with a CoolerMaster Hyper 48 heatsink with a Zalman fan running at ~1250rpm.
I agree, the last Celeron D I built ran much cooler at 3.5 GHz. than I expected - 53 C under load. 'Course with that smaller L2 cache, there's far fewer transitors generating heat than the P4!
My last 3.0 P4 Prescott also ran cooler - in the upper 50's under load which was about 10 degrees lower than my earlier P4 Prescott.
So they've made some progress, but my A64 definitely runs cooler.
Here is a pretty crazy idea so please feel free to blow it out of the water.
As we all know, the new itanics can change thier speed, dependant on need. What if the new steppings is just this function on desktop. It is common knowledge that the new chips run on lower voltage depending on need. It is also true that they draw about 115w if they are run at full load.
It does not seem to far fetched to think that, while part runs at a standard speed, the main part of the chip clocks to need. It might also explain why Intel was in such a hurry to dump the chip's speed from it's name.
