Expert solution for crt monitor
i have problem in my crt monitor ?
plz short out the problem i hv?
when i start my system my monitor power on/off LED start flickring ?
and no display appears........?
but when i strat my system i switch of my power on/off switch button , untill
operating system run......
then i push my power on/off switch "ON" my monitor show display ...!!!!
i hv takken action to find out the problem i check in another system problem creating same as before?
vga cable is ok,power cable is ok.
then what is problem behind this fault ?
plz help me?
to solve this problem?
i think there is loading problem or on/off switch problem?
plz help me
:bounce: :hello:
1 answer Last reply
More about expert solution monitor
  1. Your monitor has Alzheimer's.
CRT Monitors Switch Power Peripherals
