CommanderShepard
97
Is Dell Ultra Sharp U2312HM good enough for gaming?I read that the image is very good, but will it be enough for gaming? I care a lot about the image quality, but I don't want to see ghosting or bleeding!
gregaaron89
62
I have that monitor, I haven't noticed any ghosting though I'm not very perceptive toward that type of thing. The quality is very good, though mine does have a sort of purple glow in places from the backlight (only viewable when the screen is showing something very dark) The viewing angle is shallower than you would expect with IPS but still better than TN. But if you view it from a wider angle it makes the backlight bleed a lot worse. Looking at it straight on it's just a little bit in the corner, it's ignorable. You pretty much expect it at the price point, I can't complain.
The brightness and contrast is INSANE though, so totally worth it.
Every LCD monitor has ghosting and bleeding. It's just a matter of how much, and UltraSharps tend to be among the best.
