Archived from groups: rec.games.pinball (
More info?)
A little history anecdote, as I am very familiar with this game.
Embryon was one of the very first games, to use flash lamps as a feature.
Since the technology to generate sufficient power to run these lamps was not
available from the lamp board, they created the special circuit out of an
aux board MOC as mentioned, not related to the expander circuit. It has a
flaw, as if the MOC shorts on (and will with age and circuitry), the lamps
will obviously stay lit. If so, the playfield can burn and the clear
plastic can melt. I have seen operators place #555 bulbs in the #912
positions and make the situation worse, as even though they have a short
lifespan, can create enormous amounts of heat.
Remember the only time, the lamps will light is when both balls in the
chamber strike the targets and multi-ball.
"Life begins............"
"The_Black_Knight"
The Washington State Pinball Stronghold
"A Fortress Protecting the Silver Ball"
www.geocities.com/pinball_jack
<rondondo@comcast.net> wrote in message
news:1126386845.371773.150640@g49g2000cwa.googlegroups.com...
> Just picked up a beautiful Embryon, which I've never owned before. I
> realized that it has 4 flashers at center playfield that aren't
> working. I am convinced that there is an issue on the small auxiliary
> driver board under the playfield, but a few things have me baffled here
> before I replace the 2 obscure components on the board.
> First, according to the schematics, the auxiliary board puts out 43
> volts DC to the #912 flash lamps. 912's are 13 volt lamps, wouldn't 43
> volts blow them out immediately?
> Where does the 43 volts come from? I see that the aux. board takes in
> 6.3 volts from the feature lamp circuit, but how does it become 43
> volts? Is the S2800A on the aux board some type of amp?
> There is a feature lamp mounted beside the aux board that has no
> apparent purpose. It is also seen in the aux board schematic. It
> isn't seen through an insert or anything, just screwed to the bottom of
> the playfield. Is it simply there to test that the SCR on the main
> lamp board is working?
> Any input is appreciated!
