Is it safe for vaio battery when plugged in
G
Guest
Guest
just to ask if it is okey for my vaio battery in place, when it is plugged in. thank you very much.
G
Guest
Guest
Probably safe, but if the battery gets fully charged it's likely to shorten its life. This sounds odd -- but while there is probably built-in protection against overcharging, just fully charging the battery is bad practice.
So, when the battery indicator shows that it's nearly charged, remove it.
