G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Hi guys,
I was having a problem with my TZ resetting when holding both flippers.
Naturally the power driverboard was first to look @.
As I had a spare Funhouse with a perfectly looking board (very little
traces of heat etc etc) I decides to swap them as a quick test.
Resets remained.......
So I started to measure voltages.
Found out that the 9VAC was 8.5 VAC and this was due to the transformer
being jumpered @ 230 while wall voltage was 220.
So, I jumpered the game for 217V and the 9VAC was perfectly 9VAC now.
Resets remained........
So I measured the BR2 + side, on my meter it showed me 9VDC!
And as Marvin says it should be 12V (9VAC * root of 2 = approx 12V)
Sounds all clear as a whistle...
but, here is what I am stumped about.
I replaced the CPU board as it started to reset in attract mode as
well, with the 5V being picture perfect. I pressed on the CPU board and
the resets started again.
After this Swap the resets r gone.
But I am still left with the other readings from my multimeter than the
ones on Marvin's site.
And on top of that, all of my bridge rectifiers outputs r not what the
theory should say they should be (AC*root2=DC)
My MultiMeter is RMS.
So I started to look with a scope.
All looks fine there, and correspond with my DMM (Digital Multi Meter)
Peak is 10V, ripple is approx 2V
I see no sign of a broken diode on the sopes output.
So questions r.
How can I get 9V and Marvin 12?
Why r all my rectifiers outputs too low when calculated with the
AC*root2=DC formula?
Is Marvin perhaps reading peak voltage or something????
Hope hearing from you guys soon.
Thanx!
Hi guys,
So questions r.
Thanx!
