Need help!
Last response: in Laptops & Notebooks
September 1, 2010 6:03:08 AM
okay, so i'm having problems with my hp dv4. its battery is dead because it seems the ac adapter is not connecting to the laptop's ac plugin. the plugin seems to be physically warped (loose and wiggles) by natural wear and tear. if i use enough force and press the adapter, i may get it to charge. is there a way i can fix this? possibly replace the plugin part? any help would be appreciated.
More about : question
