radagast
Hi, I currently have a P4 2.4, but I dont think its going to cut it for my gaming needs in a couple of months. Its the weakest part in my gaming machine. But I dont know how to check what the highest processor my motherboard can handle. It probably said on the site, which was gateway, it is a 500s series from 2003. Since then I upgraded video card to a Gforce 6800 GT and a gig of RAM. So what I need to know is could I buy any P4 higher than 2.4.. say 3.0-3.4 and it will work with my motherboard? I dont know much about Processors.
Coyote
1,007
The info you provide for your motherboard is "vague". But I'll guess that's because you don't know what you've got.
Download the free copy of Everest Home Edition. Install and run it, it'll tell the motherboard (or at least the chipset). From there, use google and you'll prolly have no touble finding an article or review which will tell you the max cpu supported
Coyote
Mobile XP 2600+ (11X215)
Abit NF7-S v 2.0
Maxtor 60GB ATA 133 7200RPM
512MB Corsair Twinx 3200LL
BBA 9800 Pro
Enermax Noisetaker 420 watts
Win2K sp4
Shazbot
9
If it is a Gateway computer, try contacting Gateway and asking them what you have. Tell them the model and ask what came with it. Not sure if that helps. GL!
mrmonsoon
468
From Intels website:
General Questions:
What processor does the Intel® Desktop Board D845GEBV2 support?
The Intel® Desktop Board D845GEBV2 supports the Intel® Pentium® 4 processor and the Intel® Celeron® processor in the uPGA478-pin package. At the time of launch, the Desktop Board D845GEBV2 will support the Intel Pentium 4 processor with a System Bus of 400/533 MHz. The Desktop Board D845GEBV2 will also support the Intel Celeron processor with a 400 MHz System Bus.
Here is the url for Intel processors your chipset supports:
http://www.intel.com/design/motherbd/bv2/bv2_proc.htm
It is not a link, but copy and paste will work just fine.
The short answer is 3.06G-on the 533 front side bus.
Besides the processer, consider more ram-this helps a lot.
The chipset supports up to 512 ram cards of ddr 333 0r 266 depending on your motherboard.
