Hello, I have a P3 CPU someone gave me, but I don't know what speed it is. Is there any way I can find out the speed?
If put it in my computer without knowing the speed, can this hurt my computer?
You can read the code off the front of the chip and then search for it with google or on the Intel site...Whatever you do - don't try to force the chip into the socket.
ZIF = Zero Insertion Force.
__________________________________________________
<font color=red>You're a boil on the arse of progress - don't make me squeeze you!</font color=red><P ID="edit"><FONT SIZE=-1><EM>Edited by Rugger on 03/22/05 06:28 PM.</EM></FONT></P>
Yep there sure. Plenty of utilities out there if u got a running OS <A HREF="http://www.cpuid.com/cpuz.php" target="_new">http://www.cpuid.com/cpuz.php</A>. Don't put it in your motherboard unless you know it will work with it
If you read the writing on it you can probably google it; there is something like a serial number on it which identifies the batch. Intel and other websites will help you identify the processor.
That's the slow PIII 550. There were 3, yours (slot 1 with 512k half-speed cache), plus a Slot 1 and a Socket 370 version of the Coppermine (256k of full-speed cache). The faster cache was a lot better than simply having more slow cache.
That CPU will work in ANY Slot 1 board that supports 100MHz bus, including BX chipset boards, which were the most common back then.
Some boards require a BIOS update to properly recognize the CPU.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
