specs....
CPU-Z version 1.27.2
CPUID Output
Number of CPUs 1
APIC ID 0
Name AMD Athlon 64 2800+
Code name ClawHammer
Specification AMD Athlon(tm) 64 Processor 2800+
Family/Model/Stepping F4A
Extended Family/Model F/4
Brand ID 4
Package Socket 754
Core Stepping SH7-CG
Technology 0.13ยต
Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, x86-64
Clock Speed 1010.0 MHz
Clock multiplier x5.0
HTT Bus Frequency 202.0 MHz
P-Rating 2800+
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 1010.0 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 128 bits
eax ebx ecx edx
Function 00000000 00000001 68747541 444d4163 69746e65
Function 00000001 00000f4a 00000800 00000000 078bfbff
Function 80000000 80000018 68747541 444d4163 69746e65
Function 80000001 00000f4a 00000106 00000000 e1d3fbff
Function 80000002 20444d41 6c687441 74286e6f 3620296d
Function 80000003 72502034 7365636f 20726f73 30303832
Function 80000004 0000002b 00000000 00000000 00000000
Function 80000005 ff08ff08 ff20ff20 40020140 40020140
Function 80000006 00000000 42004200 02008140 00000000
Function 80000007 00000000 00000000 00000000 0000000f
Function 80000008 00003028 00000000 00000000 00000000
Function 80000009 00000000 00000000 00000000 00000000
Function 8000000a 00000000 00000000 00000000 00000000
Function 8000000b 00000000 00000000 00000000 00000000
Function 8000000c 00000000 00000000 00000000 00000000
Function 8000000d 00000000 00000000 00000000 00000000
Function 8000000e 00000000 00000000 00000000 00000000
Function 8000000f 00000000 00000000 00000000 00000000
Function 80000010 00000000 00000000 00000000 00000000
Function 80000011 00000000 00000000 00000000 00000000
Function 80000012 00000000 00000000 00000000 00000000
Function 80000013 00000000 00000000 00000000 00000000
Function 80000014 00000000 00000000 00000000 00000000
Function 80000015 00000000 00000000 00000000 00000000
Function 80000016 00000000 00000000 00000000 00000000
Function 80000017 00000000 00000000 00000000 00000000
Function 80000018 00000000 00000000 00000000 00000000
edx eax
MSR C0010041 00000001 00001202
MSR C0010042 00000212 000A0A02
MSR C0010015 00000000 0A000000
Chipset
Northbridge nVidia nForce3 250 rev. A1
Southbridge nVidia nForce3 LPC rev. A2
Graphic Interface AGP
AGP Revision 3.0
AGP Transfert Rate 8x
AGP SBA supported, enabled
AGP Aperture 512 MBytes
Memory Type DDR
Memory Size 1024 MBytes
Memory Frequency 202.0 MHz (CPU/5)
CAS# 3.0
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 8
Bank Cycle Time (tRC) 11
DRAM Idle Timer 16
Memory SPD
DIMM #1
General
Memory type DDR-SDRAM
Manufacturer (ID) Kingston (7F98000000000000)
Size 512 MBytes
Max bandwidth PC3200 (200 MHz)
Part number K
Serial number 6C21E958
Manufacturing date Week 07/Year 05
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 133 166 200
CAS# 2.0 2.5 3.0
RAS# to CAS# delay 2 3 3
RAS# Precharge 2 3 3
TRAS# 6 7 8
DIMM #2
General
Size 512 MBytes
Part number K
Serial number 612AC4B1
Manufacturing date Week 08/Year 05
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
CAS# 2.0 2.5 3.0
TRAS# 6 7 8
Monitoring
PCI Device List
CPU to PCI Bridge
vendor ID 0x10DE (nVidia)
device ID 0x00E1
revision 0x00A1
sub vendor ID 0x1043 (AsusTek)
sub device ID 0x813F
class code 0x06
sub class code 0x00
bus 0, device 0, function 0
Register configuration
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 DE 10 E1 00 06 01 B0 00 A1 00 00 06 00 00 00 00
10 08 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 3F 81
30 00 00 00 00 44 00 00 00 00 00 00 00 FF 00 00 00
40 43 10 3F 81 08 C0 C0 01 22 00 11 11 D0 00 00 00
50 23 05 3F 00 03 00 00 00 00 00 00 00 00 00 00 00
60 32 31 03 00 66 45 04 00 66 06 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 30 30 00 00 11 11 88 00
80 13 88 88 00 C8 00 00 00 70 00 00 00 3F 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 07 00 00 00 66 00 66 00 00 00 00 00 00 00 00 00
C0 02 00 30 00 1B 42 00 1F 12 03 00 00 FF FF FF FF
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI to ISA Bridge
device ID 0x00E0
revision 0x00A2
class code 0x06
sub class code 0x01
bus 0, device 1, function 0
00 DE 10 E0 00 0F 00 A0 00 A2 00 01 06 00 00 80 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00
40 43 10 3F 81 00 00 00 00 FA 3E FF 00 FA 3E FF 00
50 FA 3E FF 00 00 5A 62 02 00 00 00 01 00 00 FE 3F
60 01 40 00 00 01 44 00 00 01 48 00 00 00 00 F9 FF
70 10 00 FF FF 41 00 00 00 00 00 40 00 0D 00 01 00
80 09 20 00 00 8D 08 0D 00 3F 00 00 01 00 00 00 00
90 00 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 10 00 00 00 00 00 40 80 20 44 02 71 33 44 01
F0 F8 FF 5F BF 00 00 00 F0 10 FF FF FF 00 00 30 07
SMBus controller
device ID 0x00E4
revision 0x00A1
class code 0x0C
sub class code 0x05
bus 0, device 1, function 1
00 DE 10 E4 00 01 00 B0 00 A1 00 05 0C 00 00 80 00
10 81 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 01 50 00 00 41 50 00 00 00 00 00 00 43 10 3F 81
30 00 00 00 00 44 00 00 00 00 00 00 00 00 01 03 01
40 43 10 3F 81 01 00 02 C0 00 00 00 00 00 00 00 00
50 01 50 00 00 41 50 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
USB bus controller
device ID 0x00E7
revision 0x00A1
class code 0x0C
sub class code 0x03
bus 0, device 2, function 0
00 DE 10 E7 00 07 00 B0 00 A1 10 03 0C 00 00 80 00
10 00 D0 BF FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 15 01 03 01
40 43 10 3F 81 01 00 02 FE 00 00 00 00 02 00 00 00
50 00 00 00 00 1D 47 40 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 10 FF FF FF 04 0F 30 07
USB bus controller
device ID 0x00E7
revision 0x00A1
class code 0x0C
sub class code 0x03
bus 0, device 2, function 1
10 00 E0 BF FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 14 02 03 01
40 43 10 3F 81 01 00 02 FE 00 00 00 00 03 00 00 00
50 02 00 00 00 1D 47 40 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 10 FF FF FF 03 0F 30 07
USB bus controller
device ID 0x00E8
revision 0x00A2
class code 0x0C
sub class code 0x03
bus 0, device 2, function 2
00 DE 10 E8 00 06 00 B0 00 A2 20 03 0C 00 00 80 00
10 00 FC BF FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 16 03 03 01
40 43 10 3F 81 0A 80 98 20 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 20 20 01 00 00 60 98 85 07 08 00 00 00 00 00 00
70 FF 00 08 05 00 10 20 80 89 3D 80 22 77 25 04 80
80 01 00 02 FE 00 00 00 00 00 00 00 00 15 16 00 00
A0 01 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00
B0 00 11 22 33 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 10 FF FF FF 00 00 30 07
Bridge
device ID 0x00DF
revision 0x00A2
sub device ID 0x80A7
class code 0x06
sub class code 0x80
bus 0, device 5, function 0
00 DE 10 DF 00 07 00 B0 00 A2 00 80 06 00 00 00 00
10 00 C0 BF FE 01 EC 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 A7 80
30 00 00 00 00 44 00 00 00 00 00 00 00 14 01 01 14
40 43 10 A7 80 01 00 02 FE 00 01 00 00 05 00 00 00
F0 00 00 00 00 05 00 00 00 40 FF FF FF 05 23 30 07
Audio controller
device ID 0x00EA
revision 0x00A1
sub device ID 0x812A
class code 0x04
sub class code 0x01
bus 0, device 6, function 0
00 DE 10 EA 00 07 00 B0 00 A1 00 01 04 00 00 00 00
10 01 E8 00 00 01 E4 00 00 00 B0 BF FE 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 2A 81
30 00 00 00 00 44 00 00 00 00 00 00 00 15 01 02 05
40 43 10 2A 81 01 00 02 06 00 00 00 00 06 01 00 01
F0 00 00 00 00 00 00 00 00 00 FF FF FF 05 12 30 07
IDE Disk controller
device ID 0x00E5
revision 0x00A2
class code 0x01
sub class code 0x01
bus 0, device 8, function 0
00 DE 10 E5 00 05 00 B0 00 A2 8A 01 01 00 00 00 00
20 A1 FF 00 00 00 00 00 00 00 00 00 00 43 10 3F 81
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 03 01
40 43 10 3F 81 01 00 02 00 00 00 00 00 00 08 00 00
50 03 F0 00 00 00 00 00 00 A8 A8 20 20 5F 00 20 20
60 00 00 C0 C6 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 90 B5 20 00 00 02 1C 00 00 00 00
F0 00 00 00 00 00 00 00 00 02 FF FF FF 0A 14 30 07
PCI to PCI Bridge
device ID 0x00E2
revision 0x00A2
sub vendor ID 0x0000 (unknown)
sub device ID 0x0000
class code 0x06
sub class code 0x04
bus 0, device B, function 0
00 DE 10 E2 00 07 01 20 02 A2 00 04 06 00 10 01 00
10 00 00 00 00 00 00 00 00 00 01 01 0A F0 00 20 22
20 90 FC 90 FE 80 9C 70 BC 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0B 00
40 01 00 00 00 00 00 F0 3F 20 00 00 00 00 00 00 00
50 00 00 00 C0 00 F0 FF DF FF FF FF FF FF FF FF FF
60 FF 40 FF 40 00 00 00 20 00 00 00 20 FF FF FF FF
70 FF FF FF FF 00 00 00 00 00 00 00 00 FF FF FF FF
80 FF FF FF FF 00 80 01 00 CB 01 00 00 FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 1B 42 00 1F 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 03 00 00 00 00 00 00 0B 00 00 00 00 00 00 00
C0 00 00 00 00 40 00 00 80 00 00 30 07 03 0E 30 07
D0 00 00 00 00 00 00 00 00 08 00 00 C0 FF FF FF DF
PCI to PCI Bridge
device ID 0x00ED
revision 0x00A2
class code 0x06
sub class code 0x04
bus 0, device E, function 0
00 DE 10 ED 00 07 01 A0 00 A2 00 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 80 D0 D0 80 22
20 A0 FE A0 FE F0 FF 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00
40 00 00 03 00 01 00 02 00 01 00 00 00 00 00 44 00
50 00 00 FE 3F 00 00 00 00 FF 1F FF 1F 03 00 80 00
60 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
CPU to PCI Bridge
vendor ID 0x1022 (AMD)
device ID 0x1100
revision 0x0000
class code 0x06
sub class code 0x00
bus 0, device 18, function 0
00 22 10 00 11 00 00 10 00 00 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
50 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
60 00 00 00 00 E4 00 00 00 0F CC 00 0F 1C 00 00 00
80 08 00 01 21 22 00 11 11 22 05 75 80 02 00 00 00
90 56 04 51 02 00 00 FF 00 07 00 00 00 00 00 00 00
CPU to PCI Bridge
device ID 0x1101
revision 0x0000
class code 0x06
sub class code 0x00
bus 0, device 18, function 1
00 22 10 01 11 00 00 00 00 00 00 00 06 00 00 80 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 03 00 00 00 00 00 3F 00 00 00 40 00 01 00 00 00
50 00 00 40 00 02 00 00 00 00 00 40 00 03 00 00 00
60 00 00 40 00 04 00 00 00 00 00 40 00 05 00 00 00
70 00 00 40 00 06 00 00 00 00 00 40 00 07 00 00 00
B0 03 0A 00 00 00 0B 00 00 03 00 40 00 00 0B FE 00
C0 13 10 00 00 00 F0 FF 00 00 00 00 00 00 00 00 00
E0 03 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 00
CPU to PCI Bridge
device ID 0x1102
revision 0x0000
class code 0x06
sub class code 0x00
bus 0, device 18, function 2
00 22 10 02 11 00 00 00 00 00 00 00 06 00 00 80 00
40 01 00 00 00 01 08 00 00 01 10 00 00 01 18 00 00
60 00 E6 E0 03 00 E6 E0 03 00 E6 E0 03 00 E6 E0 03
80 33 00 00 00 00 00 00 00 42 35 82 13 31 0B 00 00
90 00 8C 0C 18 07 07 7B 3E 00 00 00 00 06 00 00 00
B0 02 4A 8C F2 CA 00 00 00 18 9C 5D 61 00 83 BB 0B
D0 77 5D 6F FB B6 FF DA A2 D5 6F 9E 7F DF F2 F6 67
E0 BB CF 2D AD DC 7B 6B C3 EB F5 5F 3D E7 7D 7F 66
CPU to PCI Bridge
device ID 0x1103
revision 0x0000
class code 0x06
sub class code 0x00
bus 0, device 18, function 3
00 22 10 03 11 00 00 00 00 00 00 00 06 00 00 80 00
40 FF 3B 00 00 40 00 40 02 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 80 78 B0 C9
60 3B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 11 01 02 51 11 80 00 50 00 38 00 08 1B 22 00 00
80 00 00 07 23 13 21 13 21 00 00 00 00 00 00 00 00
90 09 00 00 00 60 00 00 00 B0 67 06 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 3D 00 00 20 00 00 00 00
D0 00 00 00 00 07 07 E2 04 00 00 00 00 00 00 00 00
E0 00 00 00 00 20 0D 4C 00 08 01 00 00 00 00 00 00
VGA display controller
device ID 0x0343
revision 0x00A1
sub vendor ID 0x3842 (unknown)
sub device ID 0xA333
class code 0x03
sub class code 0x00
bus 1, device 0, function 0
00 DE 10 43 03 07 00 B0 02 A1 00 00 03 00 F8 00 00
10 00 00 00 FD 08 00 00 A0 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 42 38 33 A3
30 00 00 00 00 60 00 00 00 00 00 00 00 11 01 05 01
40 42 38 33 A3 02 00 30 00 1B 0E 00 1F 12 43 00 1F
50 01 00 00 00 01 00 00 00 CE D6 23 00 0F 00 00 00
60 01 44 02 00 00 00 00 00 00 00 00 00 00 00 00 00
Ethernet network controller
vendor ID 0x10B7 (3Com)
device ID 0x9004
revision 0x0004
sub vendor ID 0x10B7 (3Com)
sub device ID 0x9004
class code 0x02
sub class code 0x00
bus 2, device A, function 0
00 B7 10 04 90 17 01 10 02 04 00 00 02 08 80 00 00
10 01 DC 00 00 00 FC AF FE 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 B7 10 04 90
30 00 00 AC FE DC 00 00 00 00 00 00 00 13 01 0A 30
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 76
DMI
DMI BIOS
BIOS #1
vendor American Megatrends Inc.
version 1004.005
date 11/26/2004
DMI System Information
System #1
manufacturer ASUSTek Computer Inc.
product K8N
version To Be Filled By O.E.M.
serial To Be Filled By O.E.M.
UUID C09904BB-8DFED511-B0A70011-2FC45A72
DMI Baseboard
Baseboard #1
vendor ASUSTeK Computer INC.
model K8N
revision Rev 1.xx
serial MB-1234567890
DMI System Enclosure
System enclosure #1
manufacturer Chassis Manufacture
chassis type Desktop
chassis serial Chassis Serial Number
DMI Processor
CPU #1
manufacturer AMD
model AMD Athlon(tm) 64 Processor 2800+
clock speed 1818.0MHz
FSB speed 200.0MHz
multiplier 9.0x
DMI Memory Controller
Memory Controller #1
correction 64-bit ECC
Max module size 2048MBytes
DMI Memory Module
Memory Module #1
designation DIMM1
size 512MBytes (double bank)
Memory Module #2
designation DIMM2
Memory Module #3
designation DIMM3
DMI Port Connector
Port #1
designation PS/2 Mouse (internal)
designation PS2Mouse (external)
port type Mouse Port
connector PS/2
Port #2
designation PS/2 Keyboard (internal)
designation Keyboard (external)
port type Keyboard Port
connector PS/2
Port #3
designation USB1 (internal)
designation USB1 (external)
port type USB
connector Access Bus (USB)
Port #4
designation USB2 (internal)
designation USB2 (external)
port type USB
Port #5
designation USB3 (internal)
designation USB3 (external)
port type USB
Port #6
designation USB4 (internal)
designation USB4 (external)
port type USB
Port #7
designation LPT (internal)
designation LPT 1 (external)
port type Parallel Port ECP/EPP
connector DB-25 male
Port #8
designation COM 1 (internal)
designation COM A (external)
port type Serial Port 16550A
connector DB-9 male
Port #9
designation Audio1 Mic (internal)
designation Audio Mic In (external)
port type Audio Port
connector Mini Jack (headphones)
Port #10
designation Audio1 Line In (internal)
designation Audio Line In (external)
Port #11
designation Audio1 Line Out (internal)
designation Audio Line Out (external)
Port #12
designation Audio2 Mic (internal)
Port #13
designation Audio2 Line In (internal)
Port #14
designation Audio2 Line Out (internal)
Port #15
designation LAN (internal)
designation LAN (external)
port type Network Port
connector RJ-45
Port #16
designation IE1394_1 (internal)
designation IE1394_1 (external)
port type Firewire (IEEE P1394)
Port #17
designation AUX (internal)
connector On Board Sound Input From CD-ROM
Port #18
designation CD (internal)
Port #19
designation PRI_IDE (internal)
connector On Board IDE
Port #20
designation SEC_IDE (internal)
Port #21
designation SATA1 (internal)
Port #22
designation SATA2 (internal)
Port #23
designation SATA_RAID1 (internal)
Port #24
designation SATA_RAID2 (internal)
Port #25
designation SATA_RAID3 (internal)
Port #26
designation SATA_RAID4 (internal)
Port #27
designation FLOPPY (internal)
connector On Board Floppy
Port #28
designation CHA_FAN (internal)
Port #29
designation CPU_FAN (internal)
Port #30
designation PWR_FAN (internal)
Port #31
designation FP_AUDIO (internal)
Port #32
designation USB5 (internal)
Port #33
designation USB6 (internal)
Port #34
designation USB7 (internal)
Port #35
designation USB8 (internal)
Port #36
designation JOY STICK (internal)
port type Joystick Port
connector DB-15 male
Port #37
designation IE1394_2 (internal)
DMI Extension Slot
Slot #1
designation AGP
type AGP 8x
width 32 bits
populated yes
Slot #2
designation PCI1
type PCI
width 32 bits
populated no
Slot #3
designation PCI2
type PCI
width 32 bits
populated no
Slot #4
designation PCI3
type PCI
width 32 bits
populated no
Slot #5
designation PCI4
type PCI
width 32 bits
populated no
Slot #6
designation PCI5
type PCI
width 32 bits
populated yes
DMI Physical Memory Array
Physical Memory Array #1
location Motherboard
usage System Memory
correction None
max capacity 8192MBytes
max# of devices 3
DMI Memory Device
Memory Device #1
designation DIMM0
format DIMM
type DDR
total width 72bits
data width 64bits
size 512MBytes
speed 144MHz
Memory Device #2
designation DIMM1
format DIMM
type DDR
total width 72bits
data width 64bits
size 512MBytes
speed 144MHz
Memory Device #3
designation DIMM2
format DIMM
type unknown
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
My bios says im running at 1.8ghz and 400mhz on the ram bus. I can not find the speed of my cpu FSB. This shows my system running otherwise.
amd a64 2800
1gig pc3200
asus k8n
evga gf4 5700 256
is a bios setting not correct? For the most part I have everything set to auto...
--pak
everything is A-ok
______________
Who's the man with the master plan?
| Quote : Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, x86-64
I hope you are running cool&quiet, your normal multiplier should be 9.
| Quote : DMI Processor
He must be
______________
I am running cool and quiet...
Also i didnt notice that party where it said my clock speed was at 1818mhz, but shouldnt my fsb be a lot higher?
I thought my ram should run at 400 and my cpu bus was at 800.....?
--pak
Your memory bus is running @ 200mhz, but your memory is double data rate so it's effective rate is 400.
According to your post, your FSB IS a lot higher, it's at 1000, using 5x HyperTransport bus. That's 5x200MHz (HT1000). And your RAM is DDR so it's running 2x200MHz (DDR400).
Now you might get confused and say "I thought it was supposed to be 2000MHz FSB", because some people will mislead you that way, saying 1000MHz in 2 directions is 2000MHz. But that's like saying there's a 150MPH highway near my house!
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
good to hear....i will sleep better tonight.
--pak
| Quote : there's a 150MPH highway near my house! |
Cool! Where you live?
______________
Lol, I'm all for an audobon (spell?) in America
<font color=green> Woohoo!! I am officially an <b> Addict </b>!! </font color=green>
<i> <font color=red> One new Firefox fan </font color=red> </i>
<pre> Always remember to keep testicles away from live wiring </pre><p>
I think it is autobahn ...close to that anyway
-Always put the blame on you first, then on the hardware, UNLESS YOU HAVE A PROBLEM WITH A MSI BOARD !!!
Lol thanks, I just knew that wasn't correct
Post to practice my linking skills and boost my post count!
FYI
<A HREF="http://www.audubon.org/" target="_new"> audobon </A>
<A HREF="http://home.att.net/~texhwyman/autobahn.htm" target="_new"> autobahn </A>
Now that is hilarious, I was WAY off
That first link is really for the birds, and so I get another post.
That has got to be the longest question that I have ever seen! Have you met Arnold?
<b>Ned Flanders said that im a BAD ASS</b>
Intel 550(3.4)@4.2
ASUS P5AD2-E-Prem
Ballistix PC5300@DDR2 780
ATI Radeon X800XL
TT 680W PSU
| Quote : But that's like saying there's a 150MPH highway near my house! |
I miss 75MPH speed limits.
Crappy Wisconsin only goes up to 65MPH, and with the roads I take to work I usually only hit 55MPH. Oh well. At least I save gas, right?
200,000 miles or bust!
<pre><font color=white>Antec Sonata, 2x120mm fans, P4C 2.6GHz, Asus P4P800Dlx,
2x512MB CorsairXMS3200C2 in DC, Leadtek A6600GT TDH, 2xHitachi 60GB in RAID1</font color=white></pre><p>
I'm one of the ones that hate seeing the gas prices shooting through the ionosphere.
__________________________________________________
<font color=red>You're a boil on the arse of progress - don't make me squeeze you!</font color=red>
You PROBABLY save fuel. Of course older cars didn't always save fuel at slightly lower speeds, due to problems with carburation and gear ratios my '70 Cutlass got better mileage at 70 than at 65: 55-65 was bad, 75+ was horrible, the sweet spot was around 70.
Wrong: Poor people care about fuel prices and mileage and are more likely to see the relationship between supply and demand that's causing gas-guzzlers to push fuel prices skyward.
It's those rich people we call "middle class" that don't care about anyone or anything so long as they can afford to lease 2 SUV's continuously and live in overpriced housing.
Face it, if you can afford to drive 2 vehicles less than 3 years old always, live in a $150,000 home, eat at fine restaraunts once a week, build a million dollar retirement plan, own all the latest technology including plazma TV's, etc, you're wealthy, regardless of what other people say. These people who live in extreme excess are the people you're thinking of.
Would that be the famous 4 barrel carb? It became known as the 442 I think?
Intel 550(3.4)@4.2
ASUS P5AD2-E-Prem
ATI Radeon X800XL
TT 680W PSU
4 barrel carburators were the standard performance carb for all V8's, so it was a fairly generic specification. The 442 was named for having a 4-barrel, 4-speed, and Dual Exhaust.
There are 825 identified and unidentified users. To see the list of identified users, Click here.
