Tom's Hardware > Forum > CPU & Components > CPUs > Will the 6 series work on my motherboard?
Forum CPU & Components : CPUs - Will the 6 series work on my motherboard?
Ok so I have a socket 775 ASUS P5GD1 motherboard which uses the intel 915p chipset.. THG says something about the pentium 4 6** series not working on the "older" 775 motherboards.. so will it work on mine or not??
Sponsored Links
It'll work, the dual cores are the ones that wont work.
Some people are like slinkies....
Not really good for anything but you cant help smile when you see one tumble down the stairs.
Reply to Action_Man
- 0 +
Does this
<A HREF="http://www.asus.com/support/cpusupport/cpusupport.aspx" target="_new">http://www.asus.com/support/cpusupport/cpusupport.aspx</A>
help
Reply to endyen
ok great thanks for your responses everyone :)
Reply to LordPaludis
There are 808 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
