G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
I have been recently getting this weird problem when turning on my TZ.
When i power it up & get to the screen with the rom version & the
loading bar it is totally blank & nothing comes up on the screen, it
then makes the ding noise & the machine starts up normally & a few
seconds later the DMD comes on. Th DMD display looks fine theres no
distortion or missing dots or anything else wrong.
Now if i turn the machine off & then right back on, the screen comes on
fine showing the loading bar & everything. It only seems to happen if i
havent turned it on for a while.
Apart from that everything else works fine theres no switch errors & no
dreaded credit dot.
Is this somthing to be concerned about or just a weird quirk?? it just
seems weird why the DMD refuses to come on right away when i power it
on sometimes.
Thanks in advance for any help (^_^)
dreaded credit dot.
on sometimes.
