Tom's Hardware > Forum > Systems > Dell > Latitude 610 Mouse & Display Problem
Forum Systems : Dell - Latitude 610 Mouse & Display Problem
Archived from groups: alt.sys.pc-clone.dell (More info?)
At work I inherited a Latitude 610 laptop with a fresh install of XP pro,
this was 10 days ago & at first the mouse pointer used to slowly creep
across the screen, a reboot or 2 would cure the problem, in the past few
days I have experienced lockups particularly when using Outlook and Explorer
(6), on rebooting XP tells me there is a problem with the ATI Radeon display
driver.
Now the mouse pointer is creeping all the time, a reboot doesn't cure it &
it is impossible to control the computer.
Before I start doing anything rash, is this a common problem ? and how is it
repaired ?.
All replies appreciated.
Rachel
Sponsored Links
Yes it is a common problem and a large quantity of Dell laptops. the usual
fix under Dell warranty is a keyboard and palmrest replacement. If the
machine is out of warranty then you could retry reseating the KB and PR but
the chances are it will only be a short term fix and they will need
replacing
"Rachel" <rachel@btclick.com> wrote in message
news:cctrgv$5qt$2@sparta.btinternet.com...
Explorer
display
> driver.
it
> repaired ?.
> Rachel
Reply to Fixer
- 0 +
> Explorer (6), on rebooting XP tells me there is a problem with the ATI
> Radeon display driver.
> it repaired ?.
> Rachel
Common, disable the point stick or replace the keyboard.
Reply to Eugene
- 0 +
Probably a faulty pointing stick on the kybd.
Go to support.ap.dell.com/filelib and download the driver
Synaptics Touchpad, Driver, Windows 2000, Windows XP, Multi Language, Multi
System, v.7.9.3, A12
file name Tp2aa12i.exe
Once installed try disabling the pointing stick.
If still bad you will probably have to replace the keyboard & palmrest.
Note - the driver is only seems to do the disabled setting once you sign on.
I had the same issue on my C600 and ended up getting the parts replaced.
Explorer
display
> driver.
it
> repaired ?.
> Rachel
Reply to Robert
- 0 +
Many thanks to all who replied,
A hefty shove on the KB before bootup got me temporarily working again but
like you said - the problem returned the next day.
the keyboard and pam rest are being replaced under warranty - tomorrow.
thanks again.
Rachel
Reply to Rachel
There are 590 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
