Tom's Hardware > Forum > Audio > MP3 Players and Music > HELP! Sound Volume problems with Sony MZ-Nh700
Forum Audio : MP3 Players and Music - HELP! Sound Volume problems with Sony MZ-Nh700
Hey,
I recently got a Sony Mz-NH700 Hi-MD player (it´s great by the way), but I have a little problem.
When I use SonicStage to transfer the songs it works good, but when i listen to the songs in the MD the sound volume is painfully low. I have to turn it to 28-30 (max) to have a decent sound level.
And the other problem, it´s maybe a related problem, is when i turn on the EQ in the player (doesn´t matter which setting) the sound really get´s annoying.
Not only does the volume get lower than before, but the sound volume goes up and down.
For e.g when you listen to a live recording the sound of the crowd cheering is loud, but then when the band plays it get´s lower. And during to song to, depending om if the drummer plays on the kick or cymbal or anything.
It is really annoying.
How can I fix this? The mp3 and wma´s are ok, it´s not a problem with those it must be something else.
Please help,.
Thanks
Sponsored Links
Nice player by the way
Well I have a ipod mini and I had the same problem I just reinstalled the firmware. I'm not sure if thats it but its worth a try.
If its not that you might have to call sony
System Spec's:
Asus P4c800-E 3.2e @3.8ghz
1gb corsair xms pro2-2-2-5 aiw 9800 pro
audigy 2zs klipsch ultra's
74gb raptor wd 2000jb
pioneer 108 pioneer 120s
Reply to lb19984
There are 1338 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
