motherboard problem
hi i have an asus a7n266-vm motherboard with an amd duron 1300 cpu.the cpu heatsink and fan has stopped working. the computer boots up then switches off after a minute or so because of the cpu overheating, i bought a new heatsink and fan and fitted these but it still would not work. i tried connecting the cooler to the case fan connector but this still did not work.
i have tried what i thought was the faulty cooler in another pc and this works fine.
any help appreciated in solving this problem
thanks
chris
10 answers Last reply
More about motherboard problem
  1. Weird. It sounds like the CPU fan header has died. If you had a voltmeter you could check that to be sure. Otherwise you could try the generic things like blowing away dust and looking for bad capacitors. If that doesn't work you could try getting more specific like lightly sanding your CPU fan header posts, hooking the CPU fan up to a different header, or even getting a fanless heatsink so that the CPU won't overheat.
    Other than that, I can't think of anything to suggest, other than a new motherboard.
    <pre><font color=purple><i>Jesters do oft prove prophets.</i> -Regan in
    King Lear (Act V, Scene iii) by William Shakespear</font color=purple></pre><p>@ 187K -> 200,000 miles or bust!
  2. cheers mate will try that
  3. Connect the fan to a working PSU header (might have to cut and connect wire for that) to have it run. There is maybe a way to bypass the fan speed check by BIOS. use it and disable that feature in BIOS. so your BIOS will let the system boot even if it dont sense the fan running.. just like if you were water cooled..
    <font color=red>Sig space for rent. make your offer.</font color=red>
  4. Get a cheap fan that uses the standard psu molex. You have probably blown the fan trace on your mobo.
  5. Many boards won't operate long if they don't detect a CPU fan speed signal.
    <font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
    <font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
  6. So which wires are for power and which one is for the RPM monitor? (In other words: How do you splice your CPU fan wires to a molex connector for power in such a way that your mobo can still monitor the speed?)
  7. Usualy an option in BIOS... to disable fan check, as if you were running it watercooled.
  8. For a modern system, sure. What about older systems without that option though? I'm just curious myself (though I have no actual need for the information), but also thinking that cdtplug may need the info too. And if not cdtplug, then maybe someone else who finds this. You never know. It's like the molex rewire to undervolt a fan. It's weird enthusiast knowledge that most people never need but is still interesting anyway.
    I don't have a CPU HSF handy to look at, but it's only three wires and I'm guessing that there's probably a black wire for ground. So one of the remaining two is fan power and the other is the RPM info. No?
  9. The ground wire and the wire next to it are power, the third wire is fan detection.
  10. I had a super socket 7 mobo, with fan speed detect. In bios, there was an option to ignore. I sure hope there aren't any newer boards that are less capable. It used an AT psu.
CPUs Fan Motherboards
