G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Hoping maybe some Gottlieb guy can help- I have A system 3 game that
had all the playfield smart switches cut out and Williams style
switches installed. I have new smart switches to put back on but here
is the problem-Each spot target terminal in the schematics are
identified as either 1 or 2-so each smart switch has A #1 terminal and
A #2 terminal-They show A schematic of A smart swith and identify the
strobe terminal as #1 and the return as # 2-Ok so far but here is my
problem -If you look at an actual smart switch,it does not indentify
which terminal is which-The switch has 2 solder pads-one pad is round
and one pad is square?So what I need to know is which pad is #1
(strobe) and which pad is #2 (return) so I can re- install the new
switches correctly-Any help would be appreciated!!
-Thanks!-John T.
-Thanks!-John T.
