Help me to understand flat screens for tv & monitor use.
  • Flat Panel Monitors
  • Monitors
  • Peripherals
Last response: in Computer Peripherals
January 2, 2012 4:02:05 PM
Hello,
I have been researching flat screens around 37" for awhile now and there's a huge learning curve here. I'd like to get one that's long lasting as we run it a lot but also has clear text etc for computer use. We don't watch cable so I don't think hd is a big deal. I see the commercial monitors are often 720p and are made for 24/7 usage. Could we just get one of these for dvd movies, netflix, youtube videos and general computer usage? If so is there a minimum resolution required? Just looking for a basic, no frills 37" monitor that's going to last.
Need to stay under $600.
Thanks!
More about : understand flat screens monitor
a c 112 C Monitor
January 3, 2012 11:39:29 AM
hi-def is a big deal. if you've ever hooked up to a 480p/720p tv you would know why! you will want a 1080p tv.
as far as reliable brands... sony, lg, maybe samsung. avoid olevia, vizio and other cheap brands.
you dont need 120/240hz. such fancy frills might cause issues with setup (requiring a special mode for pc use)
led or ccfl backlighting. your choice. led models are thinner, lighter, better on power but are normally a little more expensive.
my recommendation?
either the 40" or 46" sony models. a relative just bought a 46" led 60hz non-3d sony bravia for about $650. i think the 40" was between $450-$550. he bought it at BJ's wholesale club but i am sure you can find a similar product elsewhere (not walmart! they get cheaper models)
m
l
January 3, 2012 6:44:29 PM
And those will work as computer monitor's as well?
m
l
a c 112 C Monitor
January 3, 2012 7:27:55 PM
i use a 40" sony bravia 60hz 1080p lcd ccfl backlight television....as my primary screen nowdays.
the only issue with using a tv is that you might have to kick up windows zoom level to +5 or +10% and have internet explorer at +5% since small text is harder to read. its not a huge issue though.
a television is a good choice for a monitor if you play games, media, and movies mostly. web browsing is okay. i'm not a huge fan of doing office work on it though as i feel smaller monitors are better for this.
a small monitor is a good choice for office work, web browsing or gaming. movies can be played but arent as immersive as a larger screen.
m
l
