HP 530 Ethernet problem
I changed OS on my hp 530 from vista home basic to Windows 7 64bit proffesional yesterday. So the Ethernet has stopped work now, i've tried to find drivers on HPs website but i can't find anything working. I've also tested update from windows update and the device manager. so now id like to ask if someone could try to help me figure out how to make it work again
Regards Petter
6 answers Last reply
More about ethernet problem
    Regards Petter
    [#0005ff]Did you run the Upgrade Compatibility Wizard to check everything would work in a 64 bit system before installing? I think you need to buy a compatible PCI ethernet card.[/#000ff]
  2. No i din't but since its a laptop we are talking about i can't change it. But do you think that it could work with a vista driver then?
    I didn't Google the model - pity it's a laptop but at least it probably has wireless. Can you enable that to turn the system loose to find a driver? The Vista one may work. I'd start off at HP's site.
  4. How did you install a 64-bit OS on this laptop? The Chipset should be 32-bit
    i'd just installed it with removing everything from the disc then just install, ill try do it the 32-bit way and reply how it workd.
  6. Problem solved! installed the 32-bit verision and it works just fine with the ethernet now.
Hewlett Packard Ethernet Card Laptops
