Closed
Replaceing my hp lcd dual lamp monitor with an hp single lamp monitor
Last response: in Laptops & Notebooks
Best solution
Monitor Authority
Laptop Authority
Who told you that?
Notebooks/laptops are generall designed to only work with certain components and no amount of tinkering will get them to work with devices not in the basic design. If your on-board video controller doesn't know how to talk to your non-native monitor, there is nothing you can do to re-program that video controller.
I think you are simply out of luck on this one.
Ask the community
