Archived from groups: microsoft.public.games.zone (More info?)
1. Click Start, point to Settings, and then click Control Panel.
2. Double-click Add/Remove Programs.
3. On the Install/Uninstall tab, click Microsoft MSN Gaming Zone or Zone,
and then click Add/Remove, or delete folder C:\Program Files\Microsoft MSN
Gaming Zone
4. Quit Internet Explorer if it is running.
5. Click Start, point to Settings, and then click Control Panel.
6. Double-click Internet.
7. Under Temporary Internet Files, click Settings, and then click View
Objects.
8. Right Click the HearbeatCtl Class program file Remove.
9. Restart your computer.
10. Perform Win Sock Fix
http://www.google.com/search?hl=en [...] gle+Search 11. Reason http://www.lavasoftsupport.com/ind [...] opic=55562 Your
Internet connectivity has been corrupted due to Spyware or the removal of
Adware components in the registry.
12. Restart your computer.
13. Visit http://zone.msn.com/en/root/default.htm?&dr=t 14. Games make take little long to load just be patient.
