I just purchased a used samsung 2433BW monitor. My graphics card is an Nvidea 88
Last response: in Computer Peripherals
- SolvedJust received my video card, seems used? when purchased new. Forum
- SolvedI just purchased two GTX 770 4gb video cards and am wondering if it will run a 4k monitor for gaming purposes without bogging Forum
- Solvedjust used an eraser on my graphics card contacts is that ok? Forum
- SolvedI just got a new Samsung monitor (S22C300H) and in 1920 x 1080 resolution it doesn't use the full screen. Forum
- SolvedUpdate my graphics card and get a new 120-144hz monitor or just get a G-Sync monitor only? Forum
- SolvedDoes my graphics card wear out faster if I use the HDMI port in the back for my monitor? Forum
- Just build Gaming pc, plugged in hdmi and on the monitor it says no signal (power is in graphics card and it is on) Forum
- SolvedHDMI Connection Problem in GTX 660 Ti Graphics Card to Monitor Samsung S22B370 Forum
- Just got a Radeon 7800 series vid card, my samsung monitor will only display a portion of my screen Forum
- I will purchase AMD fx 6100 with Asus m5a88-m Motherboard ...which graphic card Forum
- SolvedCan I use a PSU just for a graphics card? Forum
- Solvedis 22" samsung monitor heavy for nvdia g210.earlier i had 15 inch screen...will it heat up and damage my graphic card Forum
- Considering purchasing a used graphics card as an upgrade from a GT440 Forum
- SolvedDoes using a Full HD LED TV as a monitor increase the load on the graphics card and reduce its performance & life? Forum
- SolvedCan I use a DVI-D ( dual link ) to VGA adapter in DVI-I ( dual link ) port in a graphics card, to connect the monitor (VGA) Forum
- SolvedCan I use dual monitors separately with 1 graphics card? Forum
- SolvedWhich graphics card do I need to add to allow me to use 4 monitors? Forum
- SolvedCan you use a hdmi cable to connect your monitor and graphics card? Forum
- SolvedHaswell - Onboard Graphics and Video Card to Use 3 Monitors Forum
- SolvedNo sound coming from monitor when using HDMI cable from Radeon 7870 HD GHz graphics card Forum
- More resources
Read discussions in other Computer Peripherals categories
