G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Hi Guys
Need help.
Seem to have an intermittent problem with the magnet catching the ball
in the hand on my Johnny Mnemonic.Sometimes all is well and other times
the vuk kicks ball up,magnet holds for a half second to a second then
releases when it should have carried it to the matrix.
An error report on start comes up with "F5 ball in hand"
Anyone know what may be the problem and what i should look for.
I've just received new opto's for the vuk which occasionally activates
when the ball isn't there,which i'll be fitting soon.I hope this will
fix that problem.
Any ideas welcomed guys.
Cheers
Simon
Hi Guys
Need help.
fix that problem.
Cheers
Simon
