Hi,
I was having the USB problem where it gives you the "surge" error when u plug in usb in the front ports of the computer.
anyways, "i got antec case" i read couple of discussions where a dude says to cut the wire which goes into pin # 10
<a href="http://forum.msi.com.tw/index.php?threadid=57472&hilightuser=42305">LINK1</a>
and this guide from ANTEC site
<a href="http://www.antec-inc.com/specs/ezusb.html">LINK2</a>
as the site tells me over here instead of cutting the wire i took out the pin BUT INSTEAD OF WRAPPING IT IN ELECTRIC TAPE, I PUT THE WIRE FROM #10 TO THE INPUT OF #9, since #9 has no input (empty pin) and has the slot input hole taped up.
MY QUESTION is if i now put the usb in my front input of case, IS IT NOW A FIRE HAZARD. SHOULD i buy the electric tape now and wrap it around the wire after pulling it back out of the pin???
would that be safer??
i personally think wrapping a tape around something which could start fires won't stop it from starting one but i don't know much about electrical stuff.
appreciate the answer.
