Archived from groups: microsoft.public.broadbandnet.hardware (
More info?)
Sounds like you have the router configured right.
Two other places to check (both in your FTP server configuration).
i) is your ftp server using your router's WAN ip for passive mode
ii) is your ftp server set to use 4000-4049 for passive mode (if I were you,
I'd use something higher... definitely above 5000, i'd say use
50000-50049... if you do make this change, you'll also have to make the
corresponding change in your persistent port forward page on the router)
Jason Tsang - Microsoft MVP
Find out about the MS MVP Program -
http://mvp.support.microsoft.com/default.aspx
"Jorge" <jorge_j@pobox.com> wrote in message
news:3d3c01c4afe8$f94ad140$a401280a@phx.gbl...
Jason
That´s exactly the point !!!
I´ve did forwarded the range 4000-4049 to public 4000-
4049, but is not working. The PASV port number received
in the client is different of the PASV port sent by
server.
What can be wrong ?
I´m wondering if I can use a D-Link wired router (wich I
know that works fine regarding ports forwarding) to work
as my router and use my MN700 as a wireless hub for my
notebooks, like the scheme below:
Cable modem > DLink Router > MN700
> FTP server
Is it possible ? How should I proceed to ? Should I
conect the MN700 WAN port to the DLINK LAN port ?
Thanks
Jorge
>-----Original Message-----
>The router does not translate the ports at all
>So long as your forwarded range of ports goes to the
same range of ports on
>the pc, there shouldn't be problems
>ie ports 40000-40049 on the public ip -> 40000-40049 on
the private ip will
>work
>ports 40000-40049 on the public ip -> any other range of
50 ports will
>likley not work
>news:1f6e01c4ae35$42c457c0$a301280a@phx.gbl...
>Hi Jason
>I did this and the IP address in the PASV answer is OK.
>The issue is about the port number in the passive answer.
>If I don´t configure the port forwarding for the passive
>ports range, the port number in the answer received by
>the client it´s ok (but in this case client can´t access
>FTP server because de passive ports are not forwarded).
>If I configure the port forwarding for the passive ports
>range, the port number received in the client for the
>PASV command is not in the passive range defined in the
>FTP server. Seems to me that the router is translating
>the port number to a wrong port.
>Jorge
>>Did you tel your ftp server program to use the WAN ip
>for the passive mode
>>ip?
>>If that isn't done, it won't work.
>>news:31cb01c4a9c8$9905bd20$a401280a@phx.gbl...
>>Hi
>>How do I set up port forwarding to run a ftp server to
>>work in passive mode ?
>>I´ve configured my ftp server software (running in WIN
98
>>SE) to work with passive ports 5000-5049 and in my MN700
>>base setup I´ve configured a persistant forward ports
>>5000-5049 to private ports 5000-5049 and port 21 to
>>private port 21 to my internal IP address.
>>I can connect and client and server are talking, but I
>>can´t list ftp content or establish a file tranfer.
>>I´ve noticed that server answers the PASV command with
>>the correct port (5000), but client receives a different
>>answer (port 1024).
>>I´ve read in some post that in por forwarding data is
>>sent in one port and received in a different port. Is
>>this true ?
>>What am I doing wrong ?
>>Thanks
>>Jorge
