Yes No
Ads
Tom's Hardware > Forum > Computer Peripherals > Printers > Why wont my pcs see a successfully connected wireless printer?
Forum Computer Peripherals : Printers Why wont my pcs see a successfully connected wireless printer?
I have Epson WorkForce 840 and Stylus 515 printers. They are 100% successfully connected to my wireless network with static IP's. I can see and ping them from the router, but my PC's refuse to see them.
I have tried from 32 and 64 bit Windows 7 machines as well as a 32 bit Vista machine. All drivers installed. I have turned off firewalls and opened up every sharing option I can find and it just wont work. I know it is not the printers as they both are new and work fine plugged directly into the router.
Am am at a total loss. HELP!
Todd
Reply to toddcoutu
You can't ping the printer IPs at all from the computers? Did you use the same IP range and subnet as you did for the PCs? Meaning if your PCs are 192.168.1.4, your printers need to be 192.168.1.7 and not .2.7 or something.
Message edited by hang-the-9 on 02-07-2012 at 07:28:44 PM
------------------------------ Recommended Video Cards: http://www.tomshardware.com/review [...] ,3085.html
Reply to hang-the-9
I cannot ping the printers from the PC's at all, it is as if they do not exist. When I log into my router (Verizon Fios) I can see and ping the printers. I have ran the Epson configuration utility on all computers as well as attempted to set them up manually using the static IP's. I am at a total loss. The firewalls are off and all sharing is opened up. As I type this I realized that I have not disabled my malware apps, ill try that when I get home. I hardly think that would keep the PC's from even pinging them though.
Reply to toddcoutu
The IP ranges that you used on the printers are correct? Gateway, subnet, etc.. were set? The firewalls on the PC would not keep the computers connecting to the printers. Some setting in the IPs you used is not right. Try using DHCP on the printers and try to connect to the IP they get from the router automatically.
Reply to hang-the-9
You know what I need to check? I need to see if there is a Plug and Play setting on my router.
I will take another look at my IP's and make sure there is not a conflict someplace. Thanks for the attention to my issue!
Reply to toddcoutu
Plug and Play will only work for USB device configuration not IP-based. If you can't ping the printers, it's all in how the network is configured.
Reply to hang-the-9
There are 2102 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
1080 and 1200p monitors
By ssddx, 2 days ago:
hello again... remember that an actual screenshot comparing the two would be useless...
Best offers
Top experts
