I am currently building an Duron system using a gigabyte GA-7ZXE motherboard (VIA KT133A), Duron 1.1GHz and 1 stick of 256Mb 168DIMM PC133 CL3 memory.
I cannot get the system past the memory check. When booting the system hangs at the "Checking NVRAM.." message. The bus speed is currently set to 100MHz. I have replaced both the memory and processor, and tried different DIMM slots.
I unplugged all the IDE devices and this fixed the problem. It turns out the problem only occurs when th CD-ROM drive is connected. I suspect this is because it was pulled out of and old 486 machine
Can you tell me what operating system you're using? I'd be particularly interested to know if you have anything plugged into your USB ports while you're booting.
I'd rather have a full bottle in front of me than a full frontal lobotomy
This may be something you've already checked and are aware about, but is the jumper set properly for the CD-rom? Is the IDE cable oriented the right way?
<font color=blue>
Guns kill people just like spoons make Rosie O'Donnell fat.
<font color=blue>
