Acer 5516 battery not charging
Last response: in Laptops & Notebooks
October 4, 2010 10:53:26 PM
Hello, I went on holidays and when I came back the battery no longer holds a charge. Is the battery pooched or is there something I can try?
a b D Laptop
October 5, 2010 12:39:18 AM
How long have you had the battery? If you've had it for quite some time and it is the original, chances are that it is shot. Give CPUID Hardware Monitor a download, as it will tell you the condition of the battery, i.e. how much of a charge it can hold, etc... just to be sure.
m
l
October 16, 2010 1:12:42 AM
Only about 7 Months, but I don't use it very much. Tried the CPUID and it says the battery is dead. Thanks for the tip. I guess I need to go find a new cheap one. Thanks again
m
l
