Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
Well...last night my MN-700 seemed to stop broadcasting
its wireless signal. I'm using the MN-700 to wirelessly
route to an MN-720 notebook card and an MN-730 desktop
card. The three have worked nearly flawlessly for about 6
months.
Last night, it seems that the two wireless adapters no
longer "see" the router's signal. The notebook
card's "link" light just blinks. The router's wireless
light is steady.
I checked my modem by connecting it directly to my
laptop...and was surfing in seconds. However, when I
connect the modem through the router, the wireless
adapters don't pick up my network.
I installed XP sp2 on the laptop a few weeks ago...no
issues. My desktop is running ME. Like I said, I've had
no issues until last night.
I think I have a correction. The router seems to be
broadcasting, but neither adapter is finding it. I set
the router to broadcast the SSID, but to no avail.
Both machines are running Norton Anti-virus (not firewall
or internet security).
Why is it that all of the sudden won't neither adapater
can "see" the wireless network?
>-----Original Message-----
6
>months.
>light is steady.
>Any ideas what happened?? Thanks!!
I had the same problem over the weekend. Out of the blue, my MN-720
wireless card stopped seeing the MN-700. I pulled the plug on the MN-700,
and let it reboot, but that didn't help. I ended up removing the card and
software, and re-installed. After that, it came right up. I still don't
know what was the root cause.
"Zach" <anonymous@discussions.microsoft.com> wrote in message
news:278701c4aae3$c997bf80$a501280a@phx.gbl...
> months.
> light is steady.
Mike D - Thanks for the reply. I've tried all that. I
even rolled back SP2 last night...no dice. The MN-720
just sits there and blinks. It will pick up my neighbor's
network...it's always picked up hers. Seems to be blind
to mine though. Weird thing to happen so randomly.
blue, my MN-720
plug on the MN-700,
up. I still don't
message
about 6
>> months.
>> light is steady.
had
I find that my MN-700 resets periodically and hence uses
the default SSID of "MSHOME". Since my client machines
are all looking for my customized SSID, and broadcast of
SSID is suppressed, they don't see it. I have to go back
in (laptop directly wired to base station) and restore
the customized settings. Then everything works again. By
the way, my MN-700 is attached to a UPS, so the power
supply should not be causing the reset. So I still have a
puzzle as to why the base station periodically resets.
firewall
wirelessly
about
>6
>>months.
>>light is steady.
had
Have you tried right clicking on the MN-720 wireless icon in the System
Tray and clicking on repair?
news:136c01c4abaa$84bee6f0$a601280a@phx.gbl...
> blue, my MN-720
> plug on the MN-700,
> up. I still don't
> message
> about 6
>>> months.
>>> light is steady.
> had
Christian - yes...I've tried "repair". Thanks for the
idea, though. I've tried everything Windows and MS has
suggested so far.
I've had to move both PCs closer to my router to connect
to the internet via ethernet. This is turning into a very
lengthy inconvenience.
Anybody have any luck?
icon in the System
message
neighbor's
>> blue, my MN-720
>> plug on the MN-700,
>> up. I still don't
>> message
broadcasting
wirelessly
>> about 6
>>>> months.
wireless
>>>> light is steady.
>> had
