Hi,
I'm going to be assembling a system.
Here are my parts accompanied with Canadian prices.
I will be purchasing these parts from local stores, I have attached links as well.
I plan on using this system on gaming, and I will also be running various applications such as Photoshop, Dreamweaver, etc…. for school and running a website. I would like to know how well this setup will fair on gaming? Will it have good performance on the latest and greatest games like Battlefield 2 on 1024 x 768 resolution?
CPU:
AMD Athlon 64 X2 4400+ 2.2GHz Dual Core Socket 939 1MB L2 Cache $689
(http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=007268&cid=CPU.611)
Motherboard:
Asus A8N-SLI Premium $219
(http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=007442&cid=MB.693)
Video Card:
Leadtek GeForce 6800 / 256MB / PCI-Express $337
(http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1188782)
Memory:
Ultra Dual Channel 1024MB PC3200 DDR 400MHz Memory ( 2 x 512MB ) $168.99
(http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=30260)
Hard Drive:
Western Digital Caviar SATA II (WD2000JS) 200GB 7200RPM 8MB Buffer (OEM) $125
(http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=007289&cid=HD.96)
DVD Writer:
NEC ND-3540 (Silver) 16x DVD+/-R 8x DVD+RW 6x DVD-RW Writer 4x DVD-R/6x DVD+R Double Layer (OEM) $59.99
(http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=007513&cid=CR.184)
DVD Reader:
LG (CDR-8162B) 16X DVD-ROM Drive (OEM) $26.99
(http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=000211&cid=CR.196)
Case:
Premium 2531 Blue ATX Mid-Tower Case with Clear Side, Front USB and Audio Ports and Ultra X-Connect 500-Watt Power Supply $114.99
(http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1419126&Tab=5&NoMapp=0)
Floppy Drive:
Generic $10
Sub Total: $1750.96
Taxes: $262.64
Total: $2013.60
Let me know what you think about the system components, your comments and suggestions are greatly appreciated.
CPU:
Motherboard:
Video Card:
Memory:
Hard Drive:
DVD Writer:
DVD Reader:
Case:
Floppy Drive:
Generic $10
Sub Total: $1750.96
Taxes: $262.64
Total: $2013.60
