Howdy,
I wanted to know if there is any benchmarks around showing performance with C&Q enabled and with it disabled? C&Q never did much for the 3200+ I had. A few weeks ago I got an X2 4400+ so I figured C&Q would have more of an effect. I searched around a couple weeks ago about this and couldn't find much.
Yesterday I started a new game of HL2 (Single player). I was at the spot on d1_canal where you come out of the train tunnel and drop into the water. Looking out into the city and watching the Combine train go by, fps would drop down to 31-33 with C&Q enabled. Turning C&Q off and playing that same section, fps drops down to 42-43. Maybe it's just my imagination but I've also noticed an impact when using Photoshop. Things just don't seem to be as "snappy" with C&Q enabled.
The cpu will go back up to full speed, it seems, under limited circumstances. Like a constant, full load. Running 2 instances of F@H you can see it works. But applications that are more in line with real world use, it feels the software isn't fast enough. By that I don't mean the applications but the driver itself. I forgot the exact number but I remember reading a pdf about how many times the cpu could change voltage in a single second. But the request/demand for increase in speed/voltage is sent by software correct?
System:
x2 4400+
DFI LP UT Ultra-D
2x 1gb pqi turbo pc3200
eVGA 6800GT
36gb Raptor (os/apps)
XP32/sp2
System:
x2 4400+
DFI LP UT Ultra-D
eVGA 6800GT
XP32/sp2
