G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Hi folks,
Just finished cleaning my playfield with the Treasure-Cove kit, and put
a layer of wax on, then started to play.
i loaded one ball in the gumball for a toal of 4, so one should pop
out, as it always has done. The knob tries to turn then stops.
So, I forced the left/right ramp combo to try one more ball. same
thing.
Now I have 4 balls in the gumball(3 of them are down in the "carousel"
holes that turn for them to drop out.....
I went through all the test, but can't find one to exercise the
gumball to try to figure out what is going on.
The gumball has worked absolutely perfectly since I got the TZ about a
month ago..
Now, of course, since there are only 3 balls in the out hole area, it
will not advance a ball to the trough..
help, please......
Hi folks,
thing.
month ago..
help, please......
