Tom's Hardware > Forum > Games General > Games General Discussions > Electrical Issue MM after Cabinet Transfer
Forum Games General : Games General Discussions - Electrical Issue MM after Cabinet Transfer
Archived from groups: rec.games.pinball (More info?)
Help, I transfered the guts of the MM to a new BTC case. Everything
worked fine after the transfer. Last week, the Secondary Flasher fuse
blew. I changed it, everything was fine. My daughter was playing
today, and the flippers stopped working. The flipper fuses look fine.
I made sure the connectors were tight, but when I run the test for the
flippers, nothing. Any suggestions?
Sent via Gamer Newsgroups
http://www.gamernewsgroups.com
Sponsored Links
An added fact, the flipper buttons can still cause the display to
scroll through the high scores, williams message, etc, so I know they
work. The coils themselves don't power up.
Reply to Anonymous
Pull the fuse and check it with a DMM.
Is the coin door cut out switch functioning properly?
Flasher fuse might not have been part of the puzzle.
Lee
Reply to Anonymous
Check for blown fuse for flippers. LTG :)
"math08" <mathisen08@msn.com> wrote in message
news:GB1Ze.121$Aj4.6365@news.uswest.net...
Reply to Anonymous
Thanks, I will pull the fuses tomorrow to check. I did a visual and
the 4 flipper fuses looked OK, but I will put them on my meter.
The coin door seems to work. When I open it, the display flashes coin
door open.
Reply to Anonymous
Coin door has two switches, one for the alert you see, and one for high
power. If other solenoids are working, your high power switch is too. LTG :)
news:i92Ze.123$Aj4.6557@news.uswest.net...
> door open.
Reply to Anonymous
Lloyd, Thanks, thats what I thought. I put the fuses on my Volt Ohm
meter, and they all read good. Any other suggestions to try?
Reply to Anonymous
Do you have a manual?
The Trolls are on the same board as the flippers.
In test mode do the trolls work?
All of the other coils are working?
You could try reseating the connetors and the ribbon cable on the
flipper board.
Did you pull the fuses to check them or check the installed?
Lee
Reply to Anonymous
I just pulled all of the fuses and they all check out OK on my meter.
The trolls pop up on the test, but on th "hold" nothing happens. Is
this part of the problem?
Reply to Anonymous
I doubt it. Go into switch edge test, and check both flipper button opto
boards. LTG :)
news:i_fZe.29$605.3447@news.uswest.net...
Reply to Anonymous
Lloyd, the flipper boards seem OK. When I run the test they say open
and when I press the flipper button, they say closed.
Reply to Anonymous
Well now you'll have to dig a little deeper.
Power to the fliptronics board ? Power to the flipper coils ?
This may take some time, but power stops somewhere. From transformer, to
boards, to coils. You have a break. LTG :)
news:jsgZe.36$605.3538@news.uswest.net...
Reply to Anonymous
I cleaned off all of the fuse contacts and put them back in - The
flippers worked.
Played 5 or six games - no problem, in the heat of the 7th game with the
trolls up, multi ball, etc, the flippers started to die, ie, when I
tried to hold them, they would jiggle and not hold. Both flippers did
the same, and when I tried to use them, they were very sluggish.
What should I try next, or is this a different problem (did not see this
problem with the 100 or so games I played prior to moving everything
over to the new cabinet)
Thanks, Mike
Reply to Anonymous
Hey Mike,
You could try my driver board as a test to narrow it down to either the
board or the "other stuff"
Mark
> flippers worked.
> Thanks, Mike
Reply to Anonymous
Mark, I appreciate the offer.
Really strange. I was just checking again (the game was off the last
1/2 hour).
When I hold one flipper, it pulses and will not hold up. If I hold both
flippers at the same time, they hold with no problem. As soon as I let
go of one flipper the other starts to pulse and will not hold. If I
then hold the both again, they hold with no problem.
Strange wouldn't you say.
Unfortunately I probably not have time to try your board for a couple of
weeks, work comes before play, but did want to leave the game up and
running for the kids, and was hoping this would be an easy fix.
Mike
Reply to Anonymous
OK, just let me know if you want to try that if you can't get it
resolved. In the meantime, go over all the playfield wiring carefully.
Something could be a problem there I suppose.
Mark
> 1/2 hour).
> Mike
Reply to Anonymous
Fuse contacts might be worn and not holding tension, or need the solder
holding them to the board to be reflowed. LTG :)
news:BImZe.111$605.7294@news.uswest.net...
> flippers worked.
> Thanks, Mike
Reply to Anonymous
There are 542 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
