Solved
Why is there no audio output on my power dvd cyberlink
I have a collector's set of DVDs...Planet of the Apes. I have beautiful picture, but no audio. What can I do?
6 answers Last reply Best Answer
More about audio output power cyberlink
  1. specs ?
  2. Yeah and more inform I mean can you get an audio out of your PC like the start up sound or can you play a CD rom using power dvd or window media player ?
  3. I get audio on other media players. I can play a CD and get audio. I got audio on Media Player Lite, so I was able to watch the movies, but my favorite, Power DVD CyberLink, no such l luck.
  4. Best answer
    What version of Cyberlink (which is actually Roxio now, tee hee) Power DVD are you using?
    I would say that if it's a free version that came with your PC then you could try updating it. You could also look into using VLC player which is what I typically use for watching DVDs etc. because it doesn't have a ton of menus to navigate and will literally read any file thrown at it.
  5. Thanks. I'll be trying it out.
  6. Best answer selected by Rita095.
Audio Power DVD Windows 7
