Archived from groups: rec.games.pinball (More info?)
On my Haunted House, the four digit display will not show the digit "1" in
any of the four places. I have replaced Z26 on the MPU board and also
replaced Z3 (digit driver) on the display itself. I ohmed out the digit
driver ckt too. I swapped a four digit display from my Sinbad and it worked
fine with the "1" showing up. Does anyone have any ideas where to look
next?
Also, I did the ground mods suggested in marvin3m but am having trouble with
the 6 digit displays flickering from time to time. The guide says to tie
the two grounds together display boards. I found the main ground right away
but am not seeing the second ground. Any tips on this?
thanks,
Eric
I just went and put the non-working 4 digit display in my Sinbad and the "1"
digit comes in ok on that machine. Now I am starting to think connector
problems maybe?
"Eric" <estrangeway@NOcharter.SPAMMERSnet> wrote in message
news:SyfZe.13077$L45.2607@fe07.lga...
worked
> next?
with
away
> thanks,
> Eric
Yup - that was my first though.
Dem steenkin edge connectors!
-- Ed
news:YWfZe.13079$L45.1749@fe07.lga...
>"1"
> problems maybe?
>> in
> worked
>> next?
> with
> away
>> thanks,
>> Eric
Thanks Ed. Do you know if I can use crimp-on connectors with the IDC
plastic housing? I know I'll have to "double up" some of the connectors
thoguh.
thanks,
Eric
"GPE" <See_my_website_for_email@cox.net> wrote in message
news:39hZe.19237$tB5.10179@okepread06...
> -- Ed
> >"1"
> > problems maybe?
> >> in
digit
> > worked
> >> next?
> > with
tie
> > away
> >> thanks,
> >> Eric
Check out the connector section again on Clay's site. He lists the
proper crimp connector to use in the IDC housing. It works real slick.
As far as your flickering problem, I just grounded the aux. light board
and that took care of the bleed over from the backbox lighting that was
causing the flickering in my displays.
I was missing an upper row on one display of my HH and it was a broken
wire at he display it's self. I found it by using the schematics and
tracing it out.
Good luck, Dave
> thoguh.
> thanks,
> Eric
>>-- Ed
>>>"1"
>>>problems maybe?
>>>>in
> digit
>>>worked
>>>>next?
>>>with
> tie
>>>away
>>>>thanks,
>>>>Eric
Closely check the traces at the edge of the display PCB. I've had a
hairline crack there cause maddeningly intermittent display problems.
df
Thanks for the posts guys. I'll take a look at things tonite.
Does anyone know a good way to test the 6118 IC? It looks like the MPU
"strobes" the display, going between the four (or six or seven) digits fast
enough so the human eye can't tell. Any way just to test a single digit?
thanks,
Eric
"Wabajape" <dgfinck@gmail.com> wrote in message
news:1127622754.952144.304360@g44g2000cwa.googlegroups.com...
> df
logic probe
> thanks,
> Eric
>>df
!!!!! Be careful!
(Be sure you are on the +5vdc side.)
Fred
TX
CARGPB#8
"David Schulpius" <dschulpius@wi.rr.com> wrote
> logic probe
> > thanks,
> > Eric
> >>df
Thats what I was kind of thinking; a logic probe and +42V is a bad
combination.
Am I correct in assuming that the MPU "pulses" each digit quickly in order
to handle all 4 digits on one data bus? Any way just to isolate one digit?
thanks,
Eric
"Fred Kemper" <pbgarage@davlin.net> wrote in message
news
h800i0t7m@enews1.newsguy.com...
> !!!!! Be careful!
> Fred
> TX
> CARGPB#8
> > logic probe
MPU
fast
digit?
> > > thanks,
> > > Eric
> > >>df
I haven't even messed with a Sys 80 in quite some
time, and I'm not even sure it has a display test....
On WMS, and DE for example, you put the game in
display test. Get to the test that lights every _segment_,
then you can check all the lines for activity.
I don't recall this being possible on GTB, but that's
the best way.
Did you check the connectors yet? It's almost
always the issue in these games.
Fred
TX
CARGPB#8
"Eric" <estrangeway@NOcharter.SPAMMERSnet> wrote in message news:MNQZe.7$wg7.0@fe06.lga...
> combination.
> thanks,
> Eric
> news
> > !!!!! Be careful!
> > Fred
> > TX
> > CARGPB#8
> > > logic probe
> MPU
> fast
> digit?
> > > > thanks,
> > > > Eric
> > > >>df
Thanks for the tip Fred. I was leaning toward connector issues myself
because the display works in Sinbad just fine, I was just curious on how to
test the chip (that darn engineer in me). It will probably be a few days
until I work on the connectors now since I started digging into my TZ lamp
matrix column problem. Boy, I can't get 4 games to work all the time, how
do the guys with 20 machines do it?
news
h9vbm0283d@enews2.newsguy.com...
> the best way.
> Fred
> TX
> CARGPB#8
> > combination.
order
digit?
> > thanks,
> > Eric
> > news
> > > !!!!! Be careful!
> > > Fred
> > > TX
> > > CARGPB#8
> > > > logic probe
the
> > MPU
digits
> > fast
> > digit?
> > > > > thanks,
> > > > > Eric
a
problems.
> > > > >>df
Yes, they do have a multiplexed segment bus and use individual digit
strobes. You can isolate the digit drive signals at the connector. You
should see these at pins 2, 3, 5 and 6 for the digits left to right.
As always - suspect that edge connector first....
-- Ed
> combination.
> digit?
> thanks,
> Eric
> news
>> !!!!! Be careful!
>> Fred
>> TX
>> CARGPB#8
>> > logic probe
> MPU
>> > > digits
> fast
> digit?
>> > > thanks,
>> > > Eric
>> > >>df
OK, I replaced the IDC connectors with crimp-on connectors and it didn't fix
the problem (Darn it, nothings easy for me!)
Anyway, on the original HH 4 digit display, the digit "1" will not appear in
any of the digits, but the segments are good for all other numbers. I
replaced the 6118 digit chip (Z3) on the 4 digit display and replaced Z26 on
the MPU.
I swapped in my 4 digit display from my Sinbad and the "1" digit shows up,
but it is much fainter than the other number digits and "flutters" (IE it
doesn't stay on constantly, just on and off very fast).
I am starting to think to go back to the MPU. I am thinking Z22 possibly
could be a source of problems. I am going to need to spend some time with
the schematics in any case.
If you have a suggestion though, I open for advice.
thanks,
Eric
news:wi2_e.26174$tB5.16319@okepread06...
> -- Ed
> > combination.
order
> > digit?
> > thanks,
> > Eric
> > news
> >> !!!!! Be careful!
> >> Fred
> >> TX
> >> CARGPB#8
> >> > logic probe
> > MPU
> >> > > digits
> > fast
> > digit?
> >> > > thanks,
> >> > > Eric
a
problems.
> >> > >>df
news:6rn_e.3573$wg7.398@fe06.lga...
> fix
> in
> on
> the MPU.
> thanks,
> Eric
If you get a proper looking numbers on the four digit display but not a
"1" - I would give Z2 a serious looking after. And based on the other
segments looking good - I suspect Z2.
I doubt it will be Z22 for the "h" segment (number "1" ). If the CPU board
were to be at fault, my guess would have been Z17.
Good luck,
Ed
>> You
>> -- Ed
>> > combination.
> order
>> > digit?
>> > thanks,
>> > Eric
>> > news
>> >> !!!!! Be careful!
>> >> Fred
>> >> TX
>> >> CARGPB#8
>> >> > logic probe
>> >> > > the
>> > MPU
>> >> > > digits
>> > fast
>> > digit?
>> >> > > thanks,
>> >> > > Eric
> a
> problems.
>> >> > >>df
There are 1171 identified and unidentified users. To see the list of identified users, Click here.
