Caps lock volume keys
Hello,
None of my fucntion keys are working
Caps Lock, Volume, Mute, Number Lock
6 answers Last reply
More about caps lock volume keys
  1. Firstly, why the double post?
    Secondly, Is this a desktop or laptop? Make/Model?
    EDIT:
    Crap I can't spell today....
  2. I did not try to double post. I typed and posted and it asked me to register. Then the post appeared twice. Sorry about that, it was not intentional
    This is a lapto. Everything was working fine, and I must have hit a control button by accident
  3. Gateway/ NE56R12u
  4. Do you have an external keyboard you can plug into it?
    If so, plug it in and see if the issue happens with the external keyboard.
  5. I also noticed that this model has the 10-key pad so that helps.
    I looked over the manual for it and there are no special switches or anything.
  6. I don't have an extra keyboard to try. It was working fine earlier. I am not sure if I hit the function key several times.
Windows 7
