Archived from groups: rec.games.pinball (
More info?)
This may be a stupid question, but does the formula change for 220v?
The reason I ask is I will soon be moving into a home in Germany that
will allow me to set up my 10 pins, 5 vids and a juke. I seem to
recall a while back someone saying something to that effect, but can't
seem to find it.
TIA,
Rian
Mike Schudel wrote:
> > Figure 2 - 2.5A in attract mode for a modern DMD.
> > Up to 4 - 4.5A in multiball.
> > So in a 20A circuit:
> > 10 machines, maybe, if you don't play them and they are lower end power
> > draw.
> > 7 typical machines, only one in multiball.
> > 6 machines, mostly in use.
> > However, you may find that 6 machines on one circuit softens play a bit
> > if your wiring is not solid. That's your biggest concern.
> > No need whatsoever for a surge protector, on transformer pins. Anything
> > that can get through the pinball transformer will blow a surge
> > protector into smoke.
> Google for my and Kirb's independent testing. We are both EE's so the
> testing was done using some instruments, namely a Fluke 87 and 1000:1
> clamp-on CT.
> Most games whether in attract mode, being played or in multiball pull
> roughly the same current (2 to 2.5A). Sure there could be small spikes that
> would NEVER be seen by a breaker. Breakers are rated at 80%, so a 20A
> breaker is only good for a sustained current of 15 amps. Do the math, but
> that works out to 6 to 7 games per circuit depending on current draw.
> For simplicity 6 games per 20A circuit is the rule. Can more be hooked up
> per circuit? Sure, but you run the risk of tripping the circuit. Breakers
> can become weak and trip prematurely.
> Whole house surge protectors are the only way to go. One on the main panel
> and one on the sub-panel feeding the gameroom. Another good idea are surge
> receptacles that replace the existing receptacle and some even have
> replaceable MOV modules. It's good to have several layers of protection.
> Those plug in surge protectors are just a marketing gimmick. Most modern
> electronic pins have a MOV and filter as part of the line circuit
> Mike S.
> Kalamazoo, MI
> Gameroom:
http://tinyurl.com/4hfev
> W C S Owner's List:
http://tinyurl.com/39cjo
> M B Scoop Repair:
http://tinyurl.com/9lfu
