Putting a 32bit hard drive with XP into an exsisting bay on a 64bit system with
Last response: in Windows 7
It will work but you might wind up confusing your boot.ini file as to which system is the right one thus causing a possible error in regards to "bootmgr". Be sure that you set it as slave and take it out of the boot list in your BIOS and it should be fine.
If still having concerns, get an external bay and put it in there. :)
