Archived from groups: alt.sys.pc-clone.dell (More info?)
Would like to extend my monitor cable on my lcd. VGA connected. How long can
I extend the cable for ? Currently, I believe the monitor has 4 foot cable.
Would like to move a computer about three more feet, bought a 3 foot cable
extension. Is this possible without losing my signal?
Warner
-Winston
"John" <john@dontreply.net> wrote in message
news:N%hOc.1249$wz.888@fed1read01...
> can
> cable.
> Warner
> -Winston
I would think so. I've used KVM cables as long as 30' w/o signal
degradation.
"John" <john@dontreply.net> writes:
The guy I buy all my cables from says there are really good cables
and then there are also some cheap bad cables. For trade shows he
has made very high quality cables and driven monitors over 75' away.
Really good ones usually cost more, don't buy any better than you need.
See if you can find yourself a supplier who knows the difference.
can
cable.
> Warner
> -Winston
I'm using an extension cable of 25 feet right now with a Dell 4600 and NEC
Multisync monitor with no problems.
